almcc wrote:
I thought that I would update this thread after spending some time going through the bureaucracy (now that I have some time on my hands to do so!).
After spending some time with him on the phone, it's clear that if you register your PU for a RGW of over 6,000 kg. you will be forced to go through the CVOR hassle. While he said to me that he couldn't advise me to break the law, it was clear (between the lines) that if I registered the RGW for the truck to be less than 6,000 kg., I wouldn't need a CVOR. He said they would have to weigh you to determine if you are in violation of the law regarding actual weight vs. RGW
As a final check I went into the local Service Ontario office and got a confirmation today (but they said 4,500 kg.!?)..
The confusion, and it's NOT just you even staff can't figure it out, is that at 4,500 KG RGW you require a CVOR, however there is a 'personal use' exemption that allows a non-commercial use truck up to 6,000 KG without a CVOR. Above 6,000 KG there is no exemption for anything.
This was done because people were licensing bigger trucks like F-550's with a 8,864 KG GWR at 4,500 KG to avoid the CVOR requirement. This was technically possible because the curb weight was just under 4,500 KG.
