- dave54NomadNo on 36W Red Bluff to coast in an RV.
It is a motorcycle/sports car road (fun!). Not fun with anything large. - BillinwoodlandExplorer
cpaulsen wrote:
Susanville to Redding then take 299.....a good road...…….truckers use it all the time. About 3 1/2 hours from Redding to 101/
Personally, I would take 36 west to 44 and take 44 into Redding. I have traveled that route numerous times and it is somewhat shorter then taking 299. - lbrjetExplorerWe loved staying there in 2016, but cell service was limited to standing in one spot by the sign that said stand here for cell service. Not joking. Maybe it has expanded by now. Very well kept camground.
- Not_a_ClueExplorer
thanks - cpaulsenExplorer IISusanville to Redding then take 299.....a good road...…….truckers use it all the time. About 3 1/2 hours from Redding to 101/
Tin-bender wrote:
36 is not a route for an RV... 299 is fine and there is usually construction during the summer as already mentioned. Just be advised that there are 4 mountain passes to get over, all are about 4500 feet, no big deal except the west side of Oregon Mountain which is a steep decent, but go slow and no problem. Be sure to stop at the Straw House in Big Flat for lunch. If your coming up 5 from the south consider 20 at Williams across Lake County then north on 101.
Tinbender
thanks, we are coming from Susanville. - Tin-benderExplorer36 is not a route for an RV... 299 is fine and there is usually construction during the summer as already mentioned. Just be advised that there are 4 mountain passes to get over, all are about 4500 feet, no big deal except the west side of Oregon Mountain which is a steep decent, but go slow and no problem. Be sure to stop at the Straw House in Big Flat for lunch. If your coming up 5 from the south consider 20 at Williams across Lake County then north on 101.
Tinbender - Not_a_ClueExplorer
profdant139 wrote:
36 is great on a motorcycle -- not so great for an RV. I would avoid it!
299 is no problem -- the turns are not nearly as tight, lots of turnouts to let the faster vehicles go by.
The only issue with 299 is that there are almost always construction delays -- the geology in that area is rather interesting, to say the least, and the mountains are in constant motion.
Check the Caltrans website on the day that you are going to take 299 to see where the delays will be. You can't avoid them, but it is nice to know what is going on.
thank you! - profdant139Explorer III36 is great on a motorcycle -- not so great for an RV. I would avoid it!
About Bucket List Trips
13,488 PostsLatest Activity: Nov 02, 2018
