n0arp
Jan 01, 2017Explorer
DutchmenSport wrote:
The other answer would be to install a cut-off switch for each leg (or both wires), so there would be no back feed to the other plug and only one active at a time.
That is what I recommend using the ATS for instead of a junction box. If it detects power on the B leg, it switches to it, but falls back to the A leg if B leg is unpowered. Or at least that is how the one I installed last year worked.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
