GordonThree
Jan 02, 2017Explorer
DrewE wrote:
Another is to wire up the generator to what amounts to a permanent extension cord that the main AC inlet is plugged into.
This was the solution I am using. My power entry is in the back of the trailer, but my generator lives up front in the truck bed.
Went to Menards, bought a good quality 50ft 12 gauge extension cord and a bunch of that plastic wire-loom stuff. Cut the outlet end off the extension and fed it down inside the frame rail under the trailer, using the wire-loom stuff anytime it had to pass through a hole or go around a corner. Secured everything with zip ties.
To finish up, I put a 20-amp twist lock connector on the outlet end of the cord. It stays plugged into the trailer unless I'm going for shore-power.
The ten feet or so on the front of the cord is loosely coiled up and secured to the propane tank. When it's time for generator, I unbundle the cord, start the generator and plug it it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
