enblethen
Aug 21, 2012Nomad
You should look at this venting information. Refer vents on slideouts don't work as well as on non-slideouts. I would check to insure there is no void on top of the refer. They rig's manufacturer should have use some metal flashing type material to route the air coming up through the coils to ward the upper vent outlet. They should have installed blocking material so the air from the bottom vent is routed through the coils with only a small amount of clearance toward the exterior wall of the rig.
Venting
Venting
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
