Cummins12V98
Aug 23, 2012Explorer III
enblethen wrote:
Souns like you have a good start on improving the ventilation.
Did you check the upper end of the cooling unit to see if there is good exit air flow?
Yes, there is a big improvement compared to before I started. I added the third fan for when it gets above 90. and it does improve air flow when it is turned on.
By plugging the holes around the fan it made a huge difference.
I compare it to a straw with a crack in it you don't get as much flow.
I wish I knew how to post a pic.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
