Wills6_4_Hemi
Sep 21, 2012Explorer
slarsen wrote:I seen one of those while I was at MB a couple weeks ago and I almost bought it. My fridge stays cold enough but it is on the coldest setting. I am going to give them a second look. Thanks, Will
My refrig. tended in the mid-40's. A little scary. I got an inside portable refrig. fan from Tweety's that runs on two 'D' size batteries. Instructions said it would run for a month on the batteries. I doubted it, but in fact, it does.
Anyway, back to the topic: it reduced the temperature about 10 or more degrees, despite backing off one position on the temp. switch on the front of the refrigerator. And the temps are much more consistent, so no freezing things at the back while things in the door pockets are too warm. Like milk.
This might fix your problem, and for just under $20, you aren't risking much. Camping World has them, too, 'on sale' for about $16. Called a Frig Airator or some such.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
