beemerphile1
Apr 01, 2013Explorer
Cummins12V98 wrote:
...With the temps in the 90's and the frig on 4 the frig temp has ranged from 36 to 38!
The factory fans have only come on when the temps are in the mid to upper 90's.
With the continuous fan running the temp has stayed at a steady 36 when the temps are in the 80's or lower.
I had a similar situation with my pop up. See the cooling fins behind the single fan? Your problem is the air goes around those fins rather than through them.
I bent some aluminum stock to make baffles at the lower opening and the upper opening. Now all the air is forced to travel through the cooling fins and over the tubes rather than around them. I also installed two fans but have found them unneeded except for in the very hottest weather. Previously the refrigerator was about useless even in mild temperatures.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
