Cummins12V98
Apr 04, 2013Explorer III
Raften wrote:
So a question about putting a fan on top of the stack. Close off the opening except for a hole the size of the fan or fans?? I have one fan mounted up there and that only fills half or less of the stack opening. I have always felt it could pull better than it does.
Look at the pic I have a few posts up on this page. It is looking down from the top vent hole and I have since filled the hole between the two fans. With the outside temp right now near 90 the frig set on 4 is at 36 degrees. This is with the small fan I added at the top running 24/7 and the two factory fans only coming on occasionally.
Close off any gaps around the fans and it will help pull the air thru more efficiently.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
