efiguero
Jul 29, 2013Explorer
Ok, so I'm thinking of tackling this mod, so if I'm understanding the mod you can have Fans at the top and at the bottom where the main removable vent is at. So I'm assuming the fans at the top are sucking the air out the vent at the top correct? The vent at the bottom would be sucking air in or would it be sucking air out? I guess I'm just need to know which direction I need to be installing the fans, do I want them to be blowing air in or out? Has anyone done a write up on this? My particular Dometic Fridge does not seem to have any stock fans, I know for sure at the bottom main vent/hatch, I have not checked at the top vent yet but don't think it does as it's the original fridge from 98. When wiring, I'd be tapping into the power from the backside of the fridge, would I need to add a fuse for them in addition to the switch or could I just add a switch?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
