pianotuna
Feb 11, 2019Nomad III
Hi,
Yes, you can "stack" chargers. Some play well together, and some do not.
The real limitation is that 12 volt marine should only be drained by 20%. So a 100 amp-hour jar gives you 20 amp-hours to work with.
Have you switched to led bulbs?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
