pianotuna
Feb 11, 2019Nomad III
Hi,
You can do it--but the output is unregulated. If there is an eco switch--it must be turned off. Mine does only 7 amps. This may be the worst way to recharge.
dockmasterdave wrote:
I will also be using a Wen 2000 I generator to charge. I have the direct 12 v charge cables that plug straight into the generator.
Would this be a better option ?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
