dockmasterdave's avatar
Feb 10, 2019
additional battery charger
We re going to be dry camping next week for 4 days. We have 2 12v "marine deep cycle" batteries under a year old. Our on board charger is a Wfco 45 amp. I know they are basically junk and I should get a PD 45 amp.
The Wfco almost never goes into 14.4 volt mode.
Can I add a stand alone charger to help bring my batteries back up in the morning off an inverter generator ? Will the additional charger put out the 14.4 ?
How many amps do yo recommend as an add on ?
Sorry about all the questions, I don't want to damage anything and can't afford the PD yet.
  • Boon Docker wrote:
    Plug into the generator and use the converter you already have to charge the batteries for the 4 days. It will not hurt the batteries in that short period of time.
    +1. And install a solar setup as a long term solution.
  • Hi,
    Yes, you can "stack" chargers. Some play well together, and some do not.
    The real limitation is that 12 volt marine should only be drained by 20%. So a 100 amp-hour jar gives you 20 amp-hours to work with.
    Have you switched to led bulbs?
  • Hi,
    You can do it--but the output is unregulated. If there is an eco switch--it must be turned off. Mine does only 7 amps. This may be the worst way to recharge.
    dockmasterdave wrote:
    I will also be using a Wen 2000 I generator to charge. I have the direct 12 v charge cables that plug straight into the generator.
    Would this be a better option ?
  • Your flooded lead acid batteries aren't going to charge much more that 15% of their capacity. If you have 2 12V 90AH marine batteries, they likely won't accept more than 25A anyway.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
