- Golden_HVACExplorer
- GjacExplorer III
mbopp wrote:
I moved the mounts when my wife added a heavy mattress topper to the bed. It lifted it by about a ft.
Unless they're fully compressed when in the down position you might get away with just relocating the frame mounts, moving them closer to the hinge. - Golden_HVACExplorerAutoPartsByLou.com has them in various lengths and weight capacity. Make sure that you get something with enough push. My guess is something in the 75 pound range? You also need something really strong to bolt the strut to, that can take 150 pounds of force on it 24/7 - 365.
They also sell hardware, to mount the strut to the wood. You might need a metal bracket though. Some aluminum angle from Home Depot might do the trick.
I had to replace some of my basement storage door struts. I used 35 pound rated struts, they seem about right and no longer let the door slam shut, or swing open to quickly.
Fred. - mboppExplorerUnless they're fully compressed when in the down position you might get away with just relocating the frame mounts, moving them closer to the hinge.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
