bought this and an inverter from Best Converter: clicky I'm not clear on how to wire it. I have 50 amp 4 wire service and a 2,000 watt 3 wire inverter. My thinking is the circuit where the inver...
i still say there is no reason to switch the ground in fact it can be dangerous. no other transfer switch instructions i looked at showed switching the ground. if you have a electrical short to the ground wire it could burn through the transfer switch contacts on the ground wires and leave you with no ground and possible electrocution. will it work the way you wired it sure till it does not and leaves you with a open ground on your rv.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
