RoyF
May 20, 2016Explorer
The furnace is what is going to be the biggest battery drain. I suggest not running it overnight -- get a down comforter for the bed. Even if the temp drops below freezing, your water lines inside the trailer are not going to freeze overnight.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
