time2roll
May 25, 2016Nomad
9245 probably will not fit the WFCO slot. This might be why Randy recommended something else. Although perfectly fine to mount behind the power center if you have space. 9260 is shaped with a lower profile and should fit the slot. 4645 & 4655 are designed to fit in the WFCO slot.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
