MrWizard
May 31, 2015Moderator
or backup monitor was the overhead head TV..a neck breaker
i mounted a flip down video display under the cabinet .. off to the left side
and replaced the oem camera
all i had to do was get some connection adapters for the cables
remember all these cameras and displays use standard NTSC aka American video signals
you do NOT need to replace cable that is NOT bad
only need to use adapter connectors as long as the cable is good
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
