hram's avatar
hram
Intec Camera/Monitor replacement
Hello all,
I believe my Intec monitor is shot. My Holiday Rambler is all aluminum. Interested in the new wireless camera/monitor setup but concerned about it working properly through the aluminum. I already called Intec years ago and they walked me through the adjustments which no longer work. Anybody else with a similar setup and what did you do to remedy? Thanks so much for your input! Greg
  • Thank you both! I'll see what/if I can in an older used one that'll plug right in. They're fairly reasonable on ebay(but so are the wireless systems). Thanks again! Greg
  • I removed an Intec camera and monitor from my 2000 HR Endeavor. My system was a black and white version. It may be similar to your system.
    The monitor was difficult to remove as it must be pushed into the cavity behind the dash and worked around all the wiring bundles. My camera was held in place with only a huge bed of caulking.
    Consider reusing the existing 6 pin cable running from the monitor to the camera. This would take some effort to figure out the connections and a little soldering, but much easier than running a new cable.
    You may be able to use a wireless system, but I really prefer the wired systems.
    If you want to see the documentation about how I did my system, go to the link below:
    Link to changing Intec monitor/camera
    and download the file labeled "Rear View Cameras (2) & Monitor Install". You'll have to scroll down a bit to see the file.
    Fred
  • Call Here I have a intec also and the camera was no good. Got one from intec last year for $50.00 they only have one left after I purchased mine and they were not doing another run of them. Ask for Lou he might be able to find you a monitor. Just plug and play.
