swimmer_spe's avatar
swimmer_spe
Building a deck out of logs
My trailer is parked at campground. I want to build a deck and eventually enclose it in. I can make it 8 feet wide and as long as the trailer is.
I have access to about 8 pickup truck loads of wood. Realistically, Could I build a deck/enclosed room with logs?
Anyone ever done this? Anyone able to help me figure out how to do this?
  • I think the deck should be made out of pressure treated lumber or deck boards. If you use PT lumber do not leave a gap when screwed down, as the decking will shrink and leave a gap, if you do leave a gap it will entirely too wide when the boards shrink. Above ground probably does not need to be treated if painted, or stained..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,396 PostsLatest Activity: Nov 18, 2025
