profdant139's avatar
profdant139
Explorer II
Mar 20, 2018
Can water heater run while towing? Here's why . . .
I am thinking about installing a water-heater-powered underbelly tank heating system -- several of our members have already done so. A very big and daunting project, but I think it is within my competence.
The advantage of using the water heater to keep the fresh water tank from freezing is that it works even without hookups, while the electric tank heaters don't. (And I can't use my furnace to heat the tanks, both because it uses a lot of power and because there is no way to hook up a duct to the existing furnace.)
But here is my concern: if I am traveling in cold weather (let's say about zero degrees Fahrenheit) all day long, the fresh water tank is going to freeze, even if I enclose and insulate the underbelly (which of course I am going to do). So I would want to run the water heater while in transit, to keep the tank minimally warm.
At last, my question: is that possible? Will it stay lit? My fridge flame used to blow out on the road, until I installed a metal shroud around it. Would I have to do the same thing to the water heater? Is that safe?
Thanks in advance for your advice!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
