betsypupcdx's avatar
betsypupcdx
change dinette to sofa
Our 2014 class C has a dinette slide out. I'd like to remove the dinette and put in a sofa. Has anyone done this? Any pointers?
Thanks
  • Ok. How about ideas for making dinette into a seating area? Leaving the bench seats in place and adding a seat between. Making it U shaped.
  • tenbear wrote:
    One of my dinette seats has a lot of stuff under it, electrical, heater vents, etc. You should be able to fit these under the sofa but it could be a concern.
    X 2 that is all the items that operate the slide....
  • One of my dinette seats has a lot of stuff under it, electrical, heater vents, etc. You should be able to fit these under the sofa but it could be a concern.
  • Only concern I see is "will the sofa fit the space" and "will the sofa fit through the door". If yes to both, then should be easy peasy.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
