chiefward's avatar
chiefward
Change dining booth to table and chairs
Thinking about changing out my dining booth to table and chairs. Will keep the bench against the back wall since it has a handy outside access but will remove the pedestal table and one booth. I plan to install a stand alone table and two chairs but have some questions from those that has done this.
Did you attach the table to the floor?
Do you tie down the chairs for transport?
Did you regret making this modification?
Where did you find a table to fit the space?
  • We replaced a pair of theater seats with this table:
    https://www.amazon.com/gp/product/B078864X2M/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    It is not secured to the floor as we regularly move it to make more "hallway" room. We secure it to a railing beside of it with bungees.
    We bought super cheap IKEA chairs because they stack together:
    https://www.ikea.com/us/en/p/teodores-chair-green-50350939/
    We put the front legs of them over the center support of the table.
    On the other side, we built a L-shaped bench (we needed to be able to seat 4 regularly and 6 occasionally).
  • We didn't change things out like you are thinking about doing but our 5th wheel came with the dinette table and chairs. The table is bolted to the floor as well as the outside wall utilizing a cleat underneath the table where it butts against the wall and we secure the chairs during transport by turning one upside down and placing it on top of the other, cushion to cushion. Then we use bungee cords and attach them to the hooks the factory installed that are screwed to the floor. Because the chairs are tight up against the edge of the table, we use a blanket between the edge of the table and the chairs to prevent damage.
    Looks like a viable plan.
    https://www.granddesignrv.com/showroom/2020/fifth-wheel/reflection/floorplans/29rs
    Most tables are screwed to the floor.
    Chairs may or may not be strapped down.
    Any local cheaper furniture store will have different size small tables. Chairs as well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,393 PostsLatest Activity: Oct 03, 2025
