suprz
Apr 01, 2018Explorer
Changing outlets
Has anyone changed their regular AC outlets to the ones that also include USB outlets? If so what brand and how do you like them?
DrewE wrote:
The bigger problem with aluminum wiring I think was corrosion due to dissimilar metals.
Bumpyroad wrote:Blacklane wrote:
That's because screwed connections can back-off under vibration.
wasn't that the issue 40?? years back with aluminum wiring in houses. the al wire fastened to the copper screws would have a different expansion and the screw loosened to the point where fires resulted? same situation with vibration??
bumpy
Blacklane wrote:
It kind of works the other way: NFPA 1192 Standard on Recreational Vehicles says that only listed electrical fixtures, appliances, equipment and materials that have been labeled by nationally recognized testing agencies are allowed.
You can't find any fixtures with screw connections listed.
As far as the UL/CSA certification, just look on the device. Certainly the Hubbell-Wirecon self-contained devices are certified, as are virtually any other you can find.
