illpanteraa's avatar
illpanteraa
diy wiring
Hi everyone. New to RVing just purchased me first rv 76 Glendale. I'm planning on some minor upgrades in the electrical system the coach has the power convertor. I will be adding generator inverter and 4 12 volt 52 amp deep cycle scooter batteries. The converters 12 volt system is wired to run off the alt.but us missing the aux batt I kinda need some help figuring out a wiring solution I'm planning to run the gene to run the 110 side when boon docking and charge the Batts when it's running and keep charging the Batts off the alt when running the coach when the gene is off seems a little complicated I'm had at wiring and plumbing and stuff but don't want blow my converter bu adding 12 volt sources from different charging sources help would be greatly appreciated
    Suggest starting with basics, then advance into next level.
    With this in mind, below are the basics. Hope this helps.
  • Jack's Golden Rules contains a lot of information.
    BTW, next time you post, could you use some punctuation and proofread your post? For me it is barely understandable. I have no idea what "I am had..." means.
  • Welcome to the forum. I can't possibly explain what you want to know. Based on the things you have written I think you are in way over your head.
    My suggestion is to spent a lot of time reading other posts on the tech section of the forum Also spend a lot of time digging around in your RV but without changing anything. Eventually you will absorb enough knowledge to be able to ask the necessary questions to accomplish your goals.
    When asking questions be specific. Tell us what RV you have, what converter you have, what generator you have, etc. Give brands and model numbers.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
