Dakota98's avatar
Dakota98
Does anyone own a Honeywell 2000i inverter / generator ?
If you own one of these, inspect your pull rope frequently. In my opinion, there is a design flaw where the rope exits the housing. The brass ring is soft & wears rapidly causing sharp edges on it that will fray the rope. After fewer than 100 pulls on the starter, mine broke. I have since fixed it, but modified the point of exit so it won't happen again. If anyone wants info on this mod, let me know.
  • MrWizard wrote:
    I had one back in 2009
    drill the hole so that when you pull on the rope you are pulling straight up
    or straight out
    NOT dragging the rope at an angle
    drill a hole in the case
    use a teflon grommet for rope entry into the case
    Thank you! we will try that
  • I had one back in 2009
    or straight out
    I see this is an older post but was hoping we mite still find an answer.We are having the same issue,and would like to know how you solved it.TY
    I'd like to know what you did to mod the hole so it won't cut cut through again. I've replaced the rope once and the second is showing signs of were.
  • RoyB's avatar
    RoyB
    Explorer III
    My 2KW Honda EU2000i sits secured in the tail gate corner of my truck even when not camping. It gets used on a daily basis for something it seems... I got mine back in 2008 and it usually starts on first pull.
    This is the way it looks when camping -
    The Honeywell 2000i version probably is much the same as the Honda. Have not had any issues with the pull cord on the Honda.
    Roy Ken
  • Thanks for the info. I'll check my starter cord tonight. It's about 5 years old so I know I've had more than 100 pulls on the cord. I'd love to see your mod.
    The only issue I've had with mine is a gummed up carberator earlier this year. Had to disassemble it for a really good cleaning. Other than that it's been a good generator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
