bgum's avatar
bgum
Generator shelf fabrication
planning to fab a shelf on my trailer tongue to carry a generator. The generator weights a little less than 50 pounds. It will be located between the propane bottles and the camper shell over the battery. I plan to use 1 inch square tube made from aluminum or steel. Question is what material would you use and why? Difference in weight is not a factor. It will stand about 10-12 inches above battery.
  • This looks pretty cool.. Stole the image from CW, so it's for sale under $200..
  • Mitch, I really want something that sits lower, something behind the tanks and above the battery. Between the tanks and trailer itself.
    Since I have a hard tank cover something as pictured would block access to tanks. With AGM batteries I don't need access to them often. But I do appreciate the suggestion.
  • I would not want to PUT a generator between the trailer and the propane tanks,
    ISSUES ARE
    heat from the generator
    Access to the generator
    Refueling the generator
    Generator would be an ignition source, if there is a propane leak
  • I’d prefer to have gen secured in truck box. Noise isolation from trailer just one good reason.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
