stef57's avatar
stef57
Help with inverter wiring
I am installing an inverter in my 5th wheel. smallish one, 1200watts. basically only used to fire up the entertainment system on rainy days and coffee maker in the morning....
I have it hooked up to the batteries via a 200A fuse, have a 12AWG SOW wire running from it to the converter.
the plugs I want to run with it are split between 2 breakers, both are 15A
#1 has reefer & GFI plugs (kitchen, bath & outside)
#2 has converter and utility plugs
my plan is to switch the converter and the GFI plugs around so that my converter will only have to be hooked to 1 breaker to run the plugs. (GFI's and utilities)
Now my issue is, how do i make this work??:@
I want the inverter to run my plugs when i am dry camping but I want shore power to take priority when it is plugged in...
If I hook the inverter to the breaker, I will get power going back to it when shore power is hooked up right?
I thought of hooking the inverter to a disconnect switch it off before i plug in the shore cord but I guarantee that at some point I will forget to do so....:S
There is gotta be a safer and more foul proof alternative.:h
Any help would be greatly appreciated:)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 13, 2026
