jjrbus's avatar
jjrbus
HOnda 2000 extended gas tank
I am experimenting with using auxillary tank to my Honda 2000. I have clear line to see fuel moving and seem to be holding a vacuum.
The info I cannot find is when should the genset start siphoning fuel from the tank and should the vacuum from the fuel pump be measurable?
  • When I used my EU2000i while dry camping the first time, I did not see any fuel movement for a while. Went in to the trailer for about 30 minutes and came out to check and the clear fuel line was full. I think it must take a while for the built in tank to empty a bit before there is enough suction to draw from the auxiliary tank.
    I don't know anything about the fuel pump so can't help you there, however my feeling is that the fuel is not "pumped" from the auxiliary tank but instead is "drawn" or "sucked" out of it because of a vacuum formed in the regular tank. Make very sure there is no air leak in the cover of the generator tank.
    Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
