2001400ex's avatar
2001400ex
How do I replace these with LED lights
I'm not the sharpest tool in the shed. I have a 2013 shockwave toy hauler from forest river. I want to replace my bulbs with LED bulbs to reduce the power draw. But I can't get into the bulbs. I pull on the glass and the whole thing just comes down. It feels like it's spring loaded into the ceiling and I can't get the glass off to get to the bulb. I tried a screwdriver to pry it apart but can't get it to work. What am I doing wrong?
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
  • Yeah I've pulled and I'm afraid of breaking it. It just comes out of the ceiling.
  • Looks a lot like mine. That lens should just pull out. It is real tight. Held in with a flat spring type retainer.
    Mine are a G4 bulb.
    Something like these might work for you.
    http://www.amazon.com/dp/B00W1038SS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=36HHYDB8CCEAG&coliid=IY3QGR26E8B3C&psc=1
  • rhagfo wrote:
    Are you sure it isn't LED already???
    ITC RV Lighting
    I can't get in to tell. But I know when I turn on the switch that has 6 bulbs for the main part of my camper, my inverter fan gets loud meaning there's a heavy power draw.
  • brirene wrote:
    Not familiar with it, but does the cover screw off?
    I can't twist it. The whole thing turns. I also tried pulling on the metal piece in it to see if it was holding the glass in with no luck.
    Seriously can't be that difficult lol.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
