daboognish88's avatar
daboognish88
How do replace my AC unit with a Maxxair fan?
I got rid of the rotten old AC unit and want to replace it with a Maxxair. Problem is I don't know how to wire it.
Do I have to run all new wire to the battery (or wherever it runs to) or can I use the same wire but convert it somehow to connect to the Maxxair? I suspect it will be hard to run new wire through this ceiling.
The existing wire from the AC says its
12/2 WG, 600 V, (UL), ETTCOFLEX, TYPE NM
I think the AC only ever ran on shore power. So I'm not sure if this will even connect to the RV marine battery.
Any tips?
Thanks.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
