daboognish88's avatar
daboognish88
How do replace my AC unit with a Maxxair fan?
I got rid of the rotten old AC unit and want to replace it with a Maxxair. Problem is I don't know how to wire it.
Do I have to run all new wire to the battery (or wherever it runs to) or can I use the same wire but convert it somehow to connect to the Maxxair? I suspect it will be hard to run new wire through this ceiling.
The existing wire from the AC says its
12/2 WG, 600 V, (UL), ETTCOFLEX, TYPE NM
I think the AC only ever ran on shore power. So I'm not sure if this will even connect to the RV marine battery.
Any tips?
Thanks.
  • Why wouldn't the 120V solid copper wire that supplied the defunct ac unit work for powering the Maxair fan? The wire don't know if it's 12 volts dc in it or 120 volts ac.
    I'd trace the wire back to the power source, disconnect it and reconnect it to a 12 volt source to power the fan, Simple and issue solved. Use the existing wire.
  • daboognish88 wrote:
    I got rid of the rotten old AC unit and want to replace it with a Maxxair. Problem is I don't know how to wire it! I'm a complete novice when it comes to electrical work.
    Seems to me the obvious (and safest) answer is to take it to a tech who does know what he's doing. ;)
  • Are you sure you don’t want to replace the AC? Middle American gets warm in the summer months. Exhausting hot air via a fan thus pulling in hot air through the windows doesn’t cool anyone.
  • The Maxxair fan needs 12v DC. The wire you have there is the 120v AC supply for the old air conditioner. It will not work with the Maxxair. You will need to find a 12v wire already in the vicinity (maybe from a light) to power the fan, or run a new wire.
