ArcticFox_Cats's avatar
Oct 28, 2018
How do You mount/cover your Portable Generator?
(If there is a link you could send me to for replies....feel free.)
Could you help by showing me WHERE you mount your portable generator, and maybe what you use to cover it when you need to use it in bad weather. Any help, recommendations, would be welcomed.
  • I like the suggestion of put it under a table. Or anything else you already have available. Especially if one rarely uses the generator, why have something extra to carry around such as beach umbrella or similar. If one has a fifth wheel is there a problem with putting under the pin area other than the noise?
    Ours is a Champion 3400 watt inverter and the sound is barrable. I opted for a pull start model rather than an electric start to reduce weight. I can lift it into the back seat of a car if necessary. So I've not bothered to come up with a way to secure it when not in use. I just stow it away. Granted, we just bought it and I'm always looking for ideas.
    Good topic,
  • When not in use I cover with those large plastic totes.
    If the weather is very bad, heavy rain mostly, the generator(s) go under the rear of the truck.
  • It's a portable generator, so I don't "mount" it at all. I carry it in a compartment. I pull it out and set it on the ground near the shore cable. A cable and padlock prevents it from leaving home. If rain threatens, I might slide it under the trailer slide, but don't run it under there. If we must run it while raining, I just drape a cover loosely over it to shed the rain. Tarp or piece of carpet.
  • Mounting a generator takes serious bracing and exposes it to weather and theft.
  • As for covering in bad weather, I have one of those small white plastic tables from Costco that folds in half. If it rains, I set it up over the top of the Honda. Sometime I just put it under the truck tail gate.
    Bill
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jun 12, 2026
