Update:
I did a couple tests the last few nights to see how well the Hydronic Heat (via 110v hot water heater) will work as the temps get closer to zero degrees.
Saturday night the temps were in the 15 degree range. I set the thermostat to 60 degrees and in the morning the coach was at 60 degrees and the hot water heater was at 170 degrees (around the maximum temperature). Of course, the water pipes are all good to go as the hot water circulates thru them (under the kitchen sink the pipes are normally around 115 degrees). Also, the sewer compartment is kept at 48 degrees. So, that worked great - the system was able to keep up with the cold temps with no problem.
Sunday night the temps were in the 15 degree range also. I set the thermostat to 68 degrees and in the morning the coach was at 68 degrees but the water heater was at 115 degrees. Everything still worked great as the coach was at 68 degrees, but the system was probably running close to 100% of the time to keep the heat at that level. At 115 degrees in the water heater, that probably is very close to the minimum required to keep the heat at 68.
It will be interesting to see what outside/inside temperature is the "break even" point for the system. The hot water heater's recovery ability is the limiting factor along with the btu's required to keep the heat.
At some point, I'll re-test the Espar heating. I don't see that being a problem in any temperature. Basically, if you can heat the inside of your car/truck/van in below freezing temps (which I have 48yrs experience that says "Yes you can"), then the Espar heating will work without problems.
