opnspaces's avatar
opnspaces
Navigator III
May 20, 2014
I added an external water hose to my trailer
A while back I was looking for a way to add an external garden hose to my trailer. Link to thread I wanted to be able to use this hose while out boondocking so I could put out the campfire at the end of the night. Well I did complete the mod quite a while ago but never got around to posting. So below are the pictures to my modification.
I decided I was too chicken to drill any holes in the exterior of the trailer, so I had to locate the hose by a door. I didn't feel like buying a crimper so I used SharkBite fittings from Home Depot. Below is the T adapter that I cut into my cold water line to the water heater.
Here's a picture of the line running past the water heater. I put the line up on blocks for two reasons.
  • 1) It spaced the spigot at the end of the line up off the floor to make it easier to turn on and off.
  • 2) It gave a small bit of protection against things sliding up against the water heater.
Here's the picture below.
I used a 90 degree fitting to turn the corner toward the exterior door.
I then added a threaded SharkBite fitting and a ball valve. To finish off the install I screwed a quick release hose fitting on the end to give me a second layer of leak protection.
And here is my 8 year old spraying the hose and watering the desert plants. Yes I know my spart tire cover is ratty, but it keeps the sun off the spare. :)
So far I like the modification and will probably do it again on my next RV. Here's a few more pictures that I have but they are basically the same.
  • Hi All.
    That is a very nice Mod that you did. But we have an even easier way to do almost the same thing. I had an extra OOut-Side Shower Hose" that I esily connected to the "Original Outside Shower Hose, and had plenty of room for the extra Hose.
    Less than 5 minutes work, and also have a work hose to use for hat ever we chose to use it for. I did this many years, and also on our last RV, our Motorhome. And its nice to be able to tuck it all into the "Out-Side Compartment", Lock and out of site until needed.
    Good Luck. Happy Travels. Dan & Jill & our two small "YORKIE KID'S, who love to travel as much as we do. Been RV'er's, and BoonDocker's for the past 46+ years
  • It was pretty easy to do. I bought everything at Home Depot including the clamps to hold the pipe down.
    I also learned to shut off the valve and drain the pressure out of the hose before trying to disconnect the quick release. If you don't it will spray a lot of water into the storage area.
  • Thanks for sharing a great idea that I'm going to do. Just inside the basement compartment on the awning side is a pex line that at some point got crimped a bit. Have thought many a time to splice in a sharkbitie union but this is way better.
  • Old-Biscuit wrote:
    Can't remember the thread but one mod was to add a hose connection to low point drain. Hook up hose/turn on pump and spray
    That would be a very easy solution for my setup!
    Dutch_12078 wrote:
    I made a CPVC adapter that connects my outside shower hose to a garden hose. That gives me hot or cold water as needed with no plumbing modifications. Cost about a dollar.
    But I think I like this one better!
    Glad I still take the time to visit these forums!
  • I made a CPVC adapter that connects my outside shower hose to a garden hose. That gives me hot or cold water as needed with no plumbing modifications. Cost about a dollar.
  • RoyB's avatar
    RoyB
    Explorer III
    I too found it neat to always have a water hose hanging on the trailer somewhere. Seems to get used alot when I camp. Might want to squirt a squirrel. I usually fill my fresh water tank and run off the water pump at the regular camp sites anyway... Water hose is great for that...
    I use a splitter on the city water tap and hook mine water hose with spigot and usually just hang the spigot on the front deck rail of my off-road popup.
    Guess I need to something similar to your hookup so I can have one when camping back in the woods.
    Roy Ken
  • You did a nice job. It looks like a factory installation.
    The SharkBite fittings make the job easier.
  • Can't remember the thread but one mod was to add a hose connection to low point drain. Hook up hose/turn on pump and spray
