canadiankid's avatar
canadiankid
LED Lights
Looking at going LED in my trailer and was wondering if anyone has used or has an opinion on these.
  • tenbear wrote:
    JiminDenver wrote:
    wtravlr1 wrote:
    These are the ones I used from Amazon, seem to be just as bright.
    led clicky
    I used those panels but with a 921 base. Actually they come with three bases in each package. They were $3.29 each back then but I just ordered 10 more for $17.99 for a project I'm doing. I ordered them with free shipping on March 19th and they got here the 4th.
    Jim, are these the ones you ordered?
    The clicky above takes me to what appears to be a 15-1210 cob with a 921 base. :h
    Oops you were right on with the clicky. The ones I ordered were 48 1210 LED panels.
    I used denatured alcohol on the metal bases of my fixtures but they had texture already.
  • I ordered mine off of ebay paid the same price. Light wasn't the problem I had with them. Too much heat which leds should not have. If there is a campingworld near you go by there and take a look at the led fixture they have on display. You can hold you hand on it all day and it never gets warm. They want to sell you the whole fixture but it looks to me like the lamps in the fixture should fit our fixtures and of course they don't sell just the lamps. Camco has an assortment of led lamps for our fixtures. I haven't been able to find any yet nor have I found their price. If your leds are getting hot you aren't saving power.
  • None of my LEDs get "HOT", warm yes but never so hot you can't touch them. The lens on the fixture is never hot either. Then again we never have hook ups or use the lights while charging at higher voltages either. For that you need more expensive regulated LEDs.
    If you are worried about the cheap two sided tape dislodging use cob style LEDs. Falcon recently tried some 68 1210 LED cobs and seems to be pretty pleased with them.
  • 2oldman wrote:
    Cheap LEDs are the most expensive kind. Personally I'd stay off Ebay when looking for good LEDs.
    Ditto.
    I got mine here, they shipped me some when I was traveling in Canada last year when I decided I wanted a few more.
  • I ordered at 10 pac of the 48 smd panels for 17.99 and a two pac of the 1156 102 SMD cobbs.
    Both orders showed up 14 days after ordering.
    I moded the bases to put the panels in my fixtures with 1156 bulbs and I am very pleased with the result. Although, one of the panels is a slightly different colour than the others.
    I put one of the cobbs in my outdoor light and it is very bright.
    The panels do not interfere with my radio at all but the cobbs pretty much make it usless with interferance.
    I just ordered two more 10 pacs of the 10 x 48 panels to do the rest of my fixtures and have a few spares.
    These panels do get pretty hot with the trailer plugged into shore power. A couple of the panels fell off after an hour or so. I will have to find some of the high heat tape to stick them back on.
    Over all, best $17.99 I ever spent on the rig.
  • Replaced my 921's with 5050 LED'S. Now I am camped, using the antenna, and if I turn on any lights the TV quits. Try a sample before buying too many. I think that the cheap ones without the regulator is what I need.
    Usually the LED lights with a regulator will be advertised as working over a voltage range, such as 12-30 volts. However, not all lights with a regulator cause RFI (radio frequency interference).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
