7lazy77
Aug 27, 2015Explorer
zachcycles wrote:
I have used these lights for many things now, including outside (get the waterproof set) lights as you suggest. They are ALL 12 volt and run fine including the remote. The black box in the set you are looking at is the 110v to 12v converter and not needed if using your 12v RV system. I ran mine off the porch light... even put a toggle switch on the light that I can reach to switch between the two VERY different light systems. Also if you want to keep it neat dig through ebay there are angle (right and left) connectors, 'T' connectors, extension wire and mounting blocks etc...
Thanks for all the replies....and on second thought, I think I am going to change my mind & do it the way you did it (wire into my porch light & use connectors to tie it all in). The only question that I would have at this point is exactly how do I wire it up to my porch light?
Thanks again
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
