cathy97
Sep 16, 2015Explorer
I wired our LED light strip straight into the porch light and replaced the bulb in the porch light with an LED bulb. I drilled a small hole into the side of the light to run the wires through. Instead of using wire nuts I soldered the new wires to metal prongs on the back of the socket where the fixture's wires attach. It only took me about 30 minutes including mounting the LED strip under the awning. Works great!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
