grimmrlg's avatar
grimmrlg
Low cost rear electric jacks on my Class B/C
When I acquired a newer Trail-Lite 27 Class B+ coach, it had no leveling system and I had installed manual scissor stabilizing jacks to the rear of my previous coach but hated cranking them down and up. My Trail-Lite has a huge rear storage compartment across the entire rear bed, it is 34" high, 42" wide and spans the width with access door on both sides. Noting that the rear chassis frame is directly under this space, I searched and found electric jacks from Husky, model HB4500 rated at 4500 lbs on Amazon for $185 each. These are design for trailer tongue use but I welded up some frame bracket and installed two of these inside the storage bay. They work great can easily lift the entire coach rear off the ground. I additionally added a remote control to replace the included up/down switches, all at a total cost of about $400. If anyone is interesting, I will include some pics of the install.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
