mhendrickson81's avatar
Nov 12, 2017
LPG Quick Connect Y Adapter
We have an outdoor kitchen with the camper that has a 2 burner stove. I have seen lots of people that have a small gas grill with theirs as well. Many of their campers have a second connection for the grill, mine does not.
I am looking for a "Y" or "T" to put into the quick connector so I can connect both the stove and the gas grill to the LPG plumbing on the camper. That way I don't have to carry extra bottles with me everywhere we go.
Anyone ever done this? Where did you get your fittings?
  • I did the same to my Baby Q. Like the OP, I always wanted to use my Coleman stove on a Quick Connect but their is no way that I know of to get rid of the Coleman regulator. So I was thinking of using: http://www.acehardware.com/product/index.jsp?productId=51971326
    This might work for the OP depending on where your propane tanks are located.
  • Lenny K wrote:
    If your stove uses little bottles that means you have a regulator on it. You would have to remove the stove regulator if you want to use the trailer quick connect which is already regulated. Double regulated will give you a very low flame on your stove.
    BabyQ regulator removed.
  • I got this one, it's spendy but when I looked into piecing everything together there was not much price difference. I already have a quick connect on the trailer that I wanted to keep for the times I only need one gas line and when I need 2 this Y plugs right in giving me to quick connects both with shut offs. There's another Y listed for $10 less that doesn't have shut offs.
    http://propanegear.com/propane-quick-connect-y-adapter-with-shut-offs/
