Vintage465's avatar
Jan 31, 2017
Make a Smoke Generator for my Q-1000
So I am kind of new to gas grill use. The Weber Q-1000 is really the only option for me due to size constraints and I just really respect Weber products. Normally when I want to get some smoke flavor I take some aluminum foil, fold it back and forth several time to add some thickness, then sort of form it into a bowl, put dampened wood chips in it set it right on the burner and it will impart some flavor. Not real keen on the possibility of aluminum fumes.
So My thought is to take a heavy gauge stainless measuring cup......
Then fix some kind of stainless "clip" using stainless fasteners to snap over the burner.
This would likely put it just above the burner. Problem is I don't seem to be able to find a stainless clip. The ones pictured are galvanized and I have breathed plenty of galvanizing in my career as a welder and don't want it permeating my chow.
If I don't find a suitable clip I suppose I could just set it on the burner but that would snuff out about 4 to 6 little flames. Or maybe I could find some kind of stainless spacer, say a 1/4" or so high and fasten it to the cup and then set it on the burner and let it rest on back against the inside of the little grill so it doesn't fall over? They could be place so the land between flame holes in the burner.......wa-chu-tink?
  • Lack of anything to catch the drippings and create smoke was my complaint when I had a Weber-Q. I bought a baffle made for a different grill and used it. It's been several years and I can't remember the details of how I helk it in place.
    Yeah the drippings just head down to the drip pan and aren't used to enhance the products flavor. But I have to say, that's one of the things I like about it.......Easy clean up!
  • So I got the goods to assemble the little smoke generator. I originally planned on 2 clips and leaving the handle on the stainless measuring cup to rest back against the edge of the Q for stability.
    Turns out there is so little room between the burner and the grill I and to trim down the measuring cup to about an inch high and with the grill on and the little guy in place there is no way it can tip. I may look like it's not tight but it actually is. And the machine screws fastening the clip to the cup keep it up off the burner tube so the flames don't snuff out.
    From the top it looks like this. I fired the little dude up and had damp chips smoking in like 5 minutes.
    This is what the little guy looks like under the grill. Might not want to place the "product" directly over the smoke!
    There is a little wisp of smoke!
    And here is the Little Q filled with smoke. This was all done on the back of my pickup as a test run. The Grill Setting was on High. I suppose if you got it smoking on high and turned it down to low for cooking bone in chicken or ribs it would smoke for quite a bit of time. I can also experiment with damp smoking dust which last a lot longer then damp chips and chunks. I will very likely try it out when we take off for Bodega Bay on our next adventure!
  • Look into some thing like this.I'm going to make one for my Q so I can do some cold smoking on cheese.I have a big pellet smoker and do believe that the pellets will work in a Q.Just turn down the heat to go slow.
    http://smokedaddyinc.com/
  • Nice idea, I have had the Weber Baby Q like yours for 16 years. Kept out of the weather but constant use and never replaced a part! Great investment.
  • I use one of these. Filled with pellets it will last 3-4 hours. It's also great for cold smoking cheese.
    https://www.amazon.com/Amazen-Pellet-Tube-Smoker-12/dp/B00CS6YFIC/ref=sr_1_4?ie=UTF8&qid=1487181062&sr=8-4&keywords=WOOD+SMOKE+TUBE
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
