grahammcp's avatar
grahammcp
Mobile Clinic: need electrical outlets
Hello all!
I am an optometrist, and I am creating a mobile clinic to serve the local geriatric population. I recently purchased a 2003 Goshen Ford E450 shuttle bus. All seats will be removed, and I'll create a single "exam room" out of the space. I need to plug in only a few pieces of equipment (microscope with single halogen bulb, AC for summer, and small space heater for winter). This will only be used for about 8 hours per week. What would you recommend as the power source? I will be pulling up to senior care facilities, and so noise levels are a concern (so I've ruled out a generator).
Would you recommend adding a solar panel on top of the bus, or would it be easier to simply use a battery (that I can remove to recharge in my garage)? In these two scenarios, I will be dealing with a battery. What is the best way to convert from a battery to a standard 3-prong outlet? Finally, is there a go-to battery for this type of use?
Thank you!
Graham
  • AC and heater aren't going to be practical without power plug-in or generator. Solar might work if you can leave the bus running and use its HVAC system for the heating/cooling. How many watts does the other stuff draw, and how many hours/day will they be in use (are all 8 hours in 1 day, or...)?
    I'd suggest looking at the quiet inverter generators. Honda is most well known, but there are others. If you haven't heard one, you might be amazed at how quiet they can be (not sleeping in a rural campground quiet, but no noisier than city traffic quiet).
  • Can't you run a power extension cable to the facility that you are working at? Tho that may be questionable depending on how many amps the a/c and/or the heater draw. For quiet power, a 4K Honda or Yamaha generator would work but would need to be in a vented compartment. And you'd have to make sure you drain the fuel out of the carburettor when you put the bus away. Any reasonable sized battery set would probably be flatlined by the a/c or the heater.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
