StirCrazy
Sep 22, 2019Moderator
DrewE wrote:
If you want a low-pressure line for the grill, you could disconnect the furnace and water heater from the existing adapter tee fitting, remove that tee fitting, add a black iron tee and a couple of short nipples, and put the existing adapter tee back on one of the nipples and connect an appropriate flare adapter fitting to the other nipple for the grill.
You'd need to bypass the existing regulator on the grill. On some (mostly inexpensive) grills that's not readily doable as the regulator and control valve are the same unit.
yup, that's how I would do it.
you want to keep it on the big pipe so your not splitting after a smaller section
Steve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
