4X4Dodger's avatar
4X4Dodger
Explorer II
Feb 28, 2016
New Flooring Peel and Stick Tiles
As part of my redecoration of my trailer as I head north to Alaska I intend to replace the floor covering.
I would like to hear from any of you that have DIRECT experience with the peel and stick tiles.
Your comments and insights will be appreciated.
I do understand I will have to remove the existing Linoleum and stick the new tiles to the wood subfloor.
I am very interested in how you may have handled the area under your slide(s) ie that area where the slide operates over the tile.
Thanks in advance
  • We have had "peel & stick" 12" squares in our home kitchen for over 18yrs!! None have lifted, nor torn, or cracked. Not new anymore, but still look pretty good. They are installed on 1/4" plywood subfloor (not unlike your trailer floor), which was treated with a primer designed for adhesive flooring. I'm sure that you can find that still, esp now with what seems like a resurgence of "sticky" tiles.
  • They will not stick very well to the wood sub floor. You would be better off getting free floating vinyl plank or laminate.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,398 PostsLatest Activity: Oct 07, 2016
