Madmartigan's avatar
Madmartigan
New Steps Needed After Axle Flip - Recommendations?
I have a 2011 MVP Summit 25-BH travel trailer I recently bought. I went from a pretty tall 19' foot Fleetwood to this and learned quickly that the extra 6 feet of trailer length causes clearance issues. So I went in and had the axles flipped and feel much better about not ripping my drain pipes off. Now the entry steps are too high so I was just going to swap on a triple step set-up. The problem is that EVERY triple step kit I find is 27" wide at the frame where mine is 25.5". I found one guy online who had the exact same problem as me but I still can't find steps that will fit my trailer. Is my only option to saw off my existing double step assembly and weld on the wider 27" versions? Has anyone else experienced this and successfully found a solution?
