95__Scotty
Mar 24, 2014Explorer
I just replaced the front loft area of my Scotty... Sadly I lost the pics when my computer crashed.. The aluminium frame does extend completely around the bed walls.... The floor of the bed is mostly foam with 1/8" plywood glued on both sides and then fiberglass glued to the outside..... I replaced the floor with 3/4" plywood and glued the fiberglass to it. I attached to wall with stainless screws.... in hindsight I might have gone thinner plywood as 3/4 plywood doesn't have much flex. when I attached it to the sidewalls I found that I had a 1" gap at the truck roof attach point... AS my Signature states mine is a 1995.... I've been in contact with other Scotty owner's with newer Rigs and they had aluminum framework across the floor of the loft.... Good Luck with your project
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
