free_radical
Dec 03, 2017Explorer
Tiggs wrote:
Is there a product or has anyone attempted a DYI project that vents the exhaust of their portable generators above their TT? I've a Honda 2000 and have had problems in the past with the exhaust blowing back through the campsite. I dry camp a lot at dog shows so my neighbors are sometimes fairly close. The big rigs with their on board generators often exhaust their fumes up and over the top of their roofs. Would be wonderful to have something like a Genturi but designed to be used on something portable. Maybe the Genturi can be used, I don't even know. (I did search the forum for a similar topic and didn't find anything)
Carolyn
I bought a piece of metal tube for auto exhaust,removed the plastic protective cover from Honda 1000 exhaust,,and glued it onto the outlet using JB weld epoxy,,driled coresponding hole in the camper wall,,put another slightly bigger pipe thru that sealed all with silicone,,
Now I can run genny safely inside with exhaust going out,,only need to keep doors and windows closed so wind doesnt blow fumes in..
No problem as I only used it in winter charging batery when sun isnt shining..mind you
I dont stay in campgrounds so no one is bothered by the exhaust..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
