Bulletboy's avatar
Bulletboy
PORTABLE WATER MOD
Hey guys, I have a TT with a Flojet 2.9gpm pump. I want to use this to pump out a portable water tank,..through the vent hose. I was just going to Tee into it (with my bypass). First of all... can I pump back through the vent (don't want to Tee into my main 1 1/4" inlet, simply cuz there's not much hardware out there for that) 2nd...the pump will handle 15-20min of straight running eh? One last thing, if this will work...what's the simplest way to hook up a switch without disturbing the wiring that tells the pump to deliver once I get the Trailers tank filled. Hope this makes any sense to you all...any thoughts are greatly appreciated!!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
