bcsslc
Feb 03, 2015Explorer
This is what we did in ours. Easy installation and wound definitely recommend the stainless steel. I bought mine from homedepot and it was just a stock item As in no cutting. As far as the tiles go ... make sure the you clean the surface the very best you can,and let it completely dry. While it is drying layout a large section of your tile. .. about two sheets wide x four or five long. Notice how they lock together. They are designed to from left to right and from bottom to top. As far as cutting the tile, I started out with a utility knife and quickly moved to scissors. One last tip.... remove as much of the wall plates, blinds, towel rack etc. ..... as you can And then reinstall on top of the tiles.
Good luck.
Not sure others are referring to the same tile that you have inquired about. So to be clear. .. the tiles I used are a peal and stick. No setting material or grouting required. I bought all of my supplies from HD.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,406 PostsLatest Activity: Apr 28, 2026
