bobrizer2
May 17, 2016Explorer
Word of warning. IF you replace that G4 bulb with a high quality led bulb, you can forget about watching TV on your bat wing antenna when that light is on. I replaced mine only to discover that the more expensive leds contain a voltage regulator that emits an rf signal that will blank your tv signal. Google leds and tv reception for more info. Then buy the very cheapest leds you can find. This apparently doesn't happen with every brand, but you won't know until you try.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
